Like Tree262Likes
Xray T4 18
    Hide Wikipost
Old 07-17-2018, 03:49 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Xray T4 18
Last edit by: R Dodge
Welcome to the XRAY T4'18 Thread & Wikipost! Here you will find some useful info, tips and tricks as well as setups that are used by several team drivers. This wikipost is a work in progress and should continue to develop over time. Feel free to add anything you feel is useful to the community!
New for 2018:
Similar to 2017, the T4'18 kit comes available in the U.S. with either a Graphite chassis (Part no. XRA300024), or Aluminum Flex chassis (Part no. XRA300024A) along with all of the great features introduced last year. We recommend the Graphite chassis for starting on asphalt, and the Aluminum Flex for starting on carpet. The big changes for 2018 are much lower center of gravity, courtesy of the Ultra Low Profile (ULP) shocks/towers and narrower weight distribution by shifting the motor in towards the center-line of the car. In moving the motor closer to the center, the topdeck and layshaft bulkheads have been re-designed. Also new this year, the motor mount includes more holes which extend further toward the rear of the car to improve traction. With the new shorter shocks, the 2018 will use the same springs as previous T4 models.
What's NEW at T4 2018? Convert your '17 to '18 specs with these parts:
- NEW chassis plate (3 options to chose from, Graphite, Aluminum, Alum. Flex)
- NEW topdeck
- NEW ULP shocks (4mm shorter than 2017)
- NEW ULP shock towers (4mm shorter than 2017)
- NEW Motor mount (1mm narrower than 2017)
- NEW Motor mount plate
- NEW layshaft bulkheads
- NEW 51mm ECS ES driveshafts
301145 T4'18 CHASSIS 2.2MM GRAPHITE
301199 T4'18 UPPER DECK 2.0MM GRAPHITE
302084 ULP SHOCK TOWER FRONT 3.0MM GRAPHITE
303001-O T4'18 ALU LAYSHAFT BULKHEAD RIGHT - ORANGE
303002-O T4'18 ALU MOTOR MOUNT - ORANGE
303003-O T4'18 ALU MOTOR MOUNT PLATE - ORANGE
303085 ULP SHOCK TOWER REAR 3.0MM GRAPHITE
305221 ECS (ES) DRIVE SHAFT 51MM FOR 2MM PIN - HUDY SPRING STEEL(tm) (1)
305334 ECS ES (EXTRA STRONG) DRIVE SHAFT 51MM - HUDY SPRING STEEL(tm) - SET
308043-O ULP ALU SHOCK ADJUSTABLE NUT - ORANGE (2)
308308-O ULP ALU SHOCK ABSORBER-SET - ORANGE (2)
308324 ULP ALU SHOCK BODY (2)
308334 ULP COMPOSITE SHOCK PARTS
308354-O ULP ALU SHOCK CAP-NUT WITH VENT HOLE - ORANGE (2)
Tips & Tricks:
Alex Hagberg's Tech Tip Tuesday articles
How to mount your Protoform LTC-R Body
Setting static camber
How to mount weight on your chassis Part1
How to mount the rear wing on Protoform bodies
Simple troubleshooting guide
How to mount the battery on your chassis
How to glue your front tires for CRC Black carpet with Eric Anderson
Mastering the Sanwa M12S: Utilizing Exponential and RMode
How to mount weight on your chassis Part2
Mastering the Sanwa M12S: Utilizing TH-Hold
ULP Shock:
Building the new ULP Shock w/ Zero Rebound by Dominic Quek
Team driver Tim Wahl posted some very useful build tips for the T4'16 on Facebook as he worked through building a new kit. These tips will still apply on the current model.
1- Carbon Parts
2-Suspension
3-Solid Axle and Differential
4-Bulkheads & Drivetrain
5-Driveshaft (ECS & CVD)
6-Front & Rear Suspension
7-Tweak
8-Anti-Roll Bar
9-Battery Fix (OPTIONAL)
10-Bumper & Body
11-Shocks
12-Steering
Center Brace:
The manual indicates using a 2mm shim under the center brace when attaching to the chassis plate. The gap is actually 3mm, so a 3mm shim should be used here.
Tuning Note:
On Carpet we have found that adding screws or doubling up the graphite brace will make the car react quicker to steering input, & change direction faster. Raising the graphite brace off of the aluminum bulkheads by placing a shim under it on the front and rear holes will reduce response. Using the tie-rod will reduce initial response to input, but will generate more in-corner traction or 'side-bite'. Using no brace will generate even more of this 'side-bite' but all of this is at the expense of corner speed. Best to use the tie-rod or no brace only in low-traction conditions. Additionally, the center brace increases forward traction, so removing it will potentially increase wheel-spin out of low speed corners.
New Graphite Hubs:
Xray have recently released some additional Graphite hubs for the T4 lineup. The 4° Graphite C-Hub has been out for some time and is known to improve steering on entry, and in general makes the car turn better. This has been the go-to c-hub on asphalt for many on the Xray team, though it is not needed on high bite carpet. The Graphite rear hub tends to make the car more stable, especially on corner entry. We are still working on gathering input on the new Graphite steering block, but for the moment feel that it should improve steering response. All Graphite parts are approximately 1g lighter than the Hard or Medium options.
ARS Tuning courtesy of Ed (TryHard):
If you set the ARS up with no shims under either inside or outside ball positions, it actually adds toe-in under compression, at around 1° at 5.2mm ride height (how much it adds depends how much the car compresses, obviously )
Adding shims reduces the amount added (1mm under one of the links gives about 0.5°), until the link has 2mm worth of shims (1mm either side, or 2mm on one side) makes the ARS neutral. Adding more shims then turns it into reducing toe in under compression.
Whilst that might sound a bit backwards, it's actually not quite as simple as it sounds. By having the links to add toe, you gain forward traction. Also consider as the car rolls, the inside wheel is in negative compression, and the outside in compression. So the inside is toe-ing out, and the outside toe-ing in, so the whole rear is then 'steering' in the direction of the turn. Obviously the inside wheel has a lot less influence than the outside as it's far less loaded, but the effect is still there.
Optional & Tuning Parts to consider:
XRA301146 T4'18 ALU CHASSIS 2.0MM - SWISS 7075 T6 **For very high traction** (Approx. 108g)
XRA301147 T4'18 ALU FLEX CHASSIS 2.0MM - SWISS 7075 T6 **For high traction** (Approx. 93g)
XRA301169 T4'18 UPPER DECK 1.6MM GRAPHITE
XRA302254 Composite Steering Block - Graphite
XRA302334 Aluminum C-Hub Block - Caster
0° - Orange **Only for ARS**
XRA302383 Composite C-Hub Right – 4
° - Graphite (ECS) **Not recommended for high traction**
XRA302384 Composite C-Hub Left – 4
XRA302711 Brass Front Lower 1-Piece Suspension Holder - Front - FF
XRA302803 1.3mm Front Anti-Roll Bar
XRA303360 Composite Upright 0° Outboard Toe-In - Graphite
XRA303802 1.2mm Rear Anti-Roll Bar
XRA305137 Steel Solid Axle Driveshaft Adapters - HUDY Spring Steel **Highly recommend**
XRA305242 Composite Drive Shaft Replacement Cap 3.5mm – Orange – Strong (QTY 4)
XRA305351 Aluminum Wheel Hub – Offset “-0.75mm” – Black (QTY 2)
XRA305352 Aluminum Wheel Hub - Offset
“+0.75mm” - Black (QTY 2)
XRA306191 T4 Graphite + Aluminum Fully Adjustable Battery Holder
XRA308029 ULP ALU PROGRESSIVE SHOCK SYSTEM - SET (2) **Only for asphalt**
XRA308264 4S Spring-Set Progressive C=2.5-2.8 (QTY 2)
XRA308276 4S Spring-Set C=2.7 (QTY 2)
XRA308286 4S Spring-Set C=2.6 (QTY 2)
Recent Setups:
7-Oct - Alexander Hagberg - IIC - High Traction Carpet - Mod Q2, P2
7-Oct - Craig Xavier - IIC - High Traction Carpet - SuperStock Q5, P5
Print Wikipost
Old 09-07-2017, 12:36 PM
Suspended
Default Xray T4 18
https://www.teamxray.com/teamxray/ne...ec4a7b03444d0f
R Dodge is offline
Old 09-07-2017, 12:38 PM
Riketsu's Avatar
Trader Rating: 34 (100%+)
Just because Xray chose to keep the same name of T4 with different Year Versions, doesn't mean we don't need new threads...
Compare Tamiya's 416->419 cars. They are all the same, with subtle differences, yet get new threads.
Barry_Hughes and JoshuaRC10 like this.
Riketsu is offline
RC MARKET's Avatar
Trader Rating: 12 (100%+)
Japan Central said New Lower Deck , Upper Deck , Motor Mount & New Shock lower 4mm .
RC MARKET is offline
Old 09-07-2017, 12:39 PM
LookS like we're starting over folks. Excited to see the new car
DavidNERODease is offline
Old 09-07-2017, 12:41 PM
artwork's Avatar
Trader Rating: 88 (100%+)
Honestly, I was hoping for a little more...I guess until it gets released we won't know but all of these changes highlighted seem like they will only have a minor affect.
artwork is offline
Old 09-07-2017, 12:42 PM
Riketsu's Avatar
As posted by Michi Reupp on the FB Xray T4 Group:
· All-new chassis design with new motor mount plate position for further flex adjustment
· All-new top deck redesigned to fit the new layshaft bulkheads and motor mount with more center position
· All-new ESLP extremely short low profile shocks with 4mm lower design for improved stability of the car
· All-new super low profile shock towers to accomodate the new ESLP shocks
· All-new 51mm front ECS drive shafts optimized for maximum compromise between steering and stability of the car
· All-new motor & layshaft bulkhead position more in centerline for less chassis roll
· All-new motor mount plate features new extra holes more in rear for improved traction of the car
Riketsu is offline
Old 09-07-2017, 12:58 PM
RC MARKET's Avatar
maybe 13mm shock piston
Old 09-07-2017, 01:41 PM
Suspended
I think we will see a huge difference in handling with these changes. Think about what a .5 mm change does? Its huge. Lower towers, lower shocks, centralized motor are pretty big.
Bonadona and JoshuaRC10 like this.
Chris Adams is offline
Old 09-09-2017, 05:29 AM
Lone Drifter's Avatar
Looks like changes that will keep Xray more competitive with Awsomatix
( cant wait to race against these newer better cars in VTA )
Lone Drifter is offline
Old 09-09-2017, 11:57 AM
JEFFs SC10's Avatar
Trader Rating: 15 (100%+)
I'm getting one from ProlevelRC.
chensleyrc1 likes this.
JEFFs SC10 is offline
Old 09-09-2017, 01:22 PM
Airwave's Avatar
Originally Posted by Lone Drifter
Looks like changes that will keep Xray more competitive with Awsomatix :tire
WHAT?
Airwave is offline
Old 09-09-2017, 05:01 PM
Originally Posted by Airwave
WHAT?
As someone with 2 Xrays, I hate to say it, but the AMX is stomping everyone, in the slower classes. VTA/USGT. Look at the Wiki page for USGT--AMX dominated in Cleveland.
tandman likes this.
mooby64 is online now
Old 09-09-2017, 10:27 PM
JEFFs SC10's Avatar
those are more driving classes than anything, I wouldn't say it is totally due to the chassis.
At the last Snowbirds there were A LOT of Xrays in the A mains..
Ggrant likes this.
Old 09-10-2017, 02:09 AM
I think the awesomatrix has a very slight advantage pace wise right now and I literally mean SLIGHT !!! Nothing to go all gun ho about !!! But as saying that , in Europe Xray is king in all classes . The awesomatrix doesn't do as good across there as they do here . Better drivers running the car across here maybe ? !! Ive had 3 of those cars until last week . Couldn't handle them anymore !! Car handled great , but with the awesomatrix you gotta live with all the little quirks that comes with the car like slight taps of the boards and ur setting would be off , honestly I don't know what alum they use but I don't think it's 7075 !!! I've stripped 3 bulkheads trying to screw in the top deck screws and no I'm not hulk so I didn't screw them in too tight ! Also the turnbuckles are literally garbage !!! Weak as fuck !!! So u see with the changes that I see Xray has made to their T4 18 I think will literally swing the tide of power back xray's way and balance the playing field somewhat . Good job Xray and looking forward to seeing / driving ur new beast
mazmorbid likes this.
Ggrant is offline
Old 09-10-2017, 06:23 AM
Don't get me wrong, I love my T4's. Durability being the #1 factor.
It will be interesting what parts will carry over to the new '18.
